Guest kouki240sx Posted August 21, 2011 Share Posted August 21, 2011 I need your manual swap I have this ka24de or a set of "18 spartan adr rims black w/chrome 5-speed Drive shaft front and rear sections (No ABS) M/T flywheel bolts Clutch Kit (Throwout bearing, Pressure Plate, alignment tool) Shifter assembly (plate, lower rubber boot, upper leather boot, finisher plate) 5-speed Cross member Clutch Master cylinder Clutch Slave cylinder Clutch hardlines Clutch rubber line and dampener line Clutch pedal assembly 5-Speed Brake pedal assembly or a cut brake pedal Bellhousing bolts for a 5 speed bellhousing Bolts to hold Pressure Plate to Flywheel Quote Link to comment Share on other sites More sharing options...
