engine mounts for a 280ZX
  • 3 weeks later...
JTR mount PN's and shim stack height works fine, just don't use the offset plates.
700R4 only needs one bolt hole to bolt up the tranny mount, make it any way you want that's fairly easy to undo if you need tranny servicing so you can drop the tailshaft down etc. A single flat plate of steel across the bottom of your tunnel can work fine and then find your proper height for the mount and safely shim the appropriate height and then have that built into your mount. nothing ideal about my geometry right now or my mount (all being changed) so no point copying my setup yet.
quote:
Originally posted by ChrisM:
wondering if anyone has any drawings/mesurements for engines and tranny (th350 or 700r4) for a 280ZX? any help would be GREAT!
