earthcruiser Posted September 17, 2011 Share Posted September 17, 2011 I have search the forums and have found a couple websites that will get the conversion half way. My problem is that I am running an Automatic trans and am trying to convert to a 12-80 ignition module. This is how I have the wires connect so far after looking at the websites and the shop manual. The Red/Blue wire to Negative Coil The Ignition Module Negative to the Negative Coil Connect the Green White Wire and the Black White Wire that ran to the Ballast The Blue Wire to the Positive Coil The Ignition Module Positve to the Positive Coil The Black/White Wite to the Positive Coil That leaves me with a unconnected solid black wire. Where does it go? Are there any errors in my process above. Please Assist. Thank you. Rod Quote Link to comment Share on other sites More sharing options...
beermanpete Posted September 17, 2011 Share Posted September 17, 2011 Typically, solid black is ground. Quote Link to comment Share on other sites More sharing options...
