1jzgte into 1977 280z tach wiring
z31t
Hello everybody my name is Felix and Im in the middle of a 1jzgte swap into my 77z as the title states. I really want to stick with the stock gauge cluster and I have already got the oil pressure and water temp gauges working but Im having trouble getting the tach to operate. I tried searching and can't find any concrete answers that I haven't tried already.
Here are some pics of the car the day I started it up and took it around the block.
The hood isn't on because I'm waiting on a 90 degree fitting for the oil line so I'm riding around getting the bugs out of it like this.
And my other cars so you know Im a z nut. The red one is a sohc vg30 that makes 620whp and the other is a stock lowered shiro in need of a front lip
Thank you
  • 1 month later...
The reason the Tacho won't operate is because you have a tach that is designed for a single coil input, but you are using a coil on plug type ignition system with multiple coils. You will need a Tach adapter from MSD or Dakota Digital(I prefer this one). Wire it in, adjust as needed and you will have a working tach
  • 4 weeks later...
Thank you for the response, I've tried the msd tach adapter because I had one lying around the shop but the dakota digital unit you referenced looks promising. I've got the car running about 17psi now and making 440whp but I would still like to get all these small loose ends tied up.
really happy with the swap overall, its a ton of fun on the road.
