1983 5 speed shift q
duragg
Once in a while I pop out of 2nd gear.
Rebuilt with new bearings and syncros 3 months ago.
Would a stiffer spring on the ball bearing for 2nd help that?
When I took it apart I vaguely remember a different spring setup under one of the caps.
It might help, but that is not the problem. A bent shift fork might cause it to pop out of gear. Or the syncro could be worn out again if your thrashing the second gear shift alot.
