260z booster vacum leak
I was wondering what should I do about my situation. I found a major vaccum leak in between where the flange of the brake master cylinder and the brake booster make contact. I did this by sprraying water and shure enough air bubbles did appear. Should i just tighten the bolts; apply some sort of sealant? Any suggestion would be great.
Below is an image found on google. I have post it just as an example of where exactly my leak is coming from.
Edited by David GArcia
An air leak at the location you describe would be caused by a bad seal in the brake booster. You will need to rebuild your booster.
