JSM Posted November 2, 2011 Share Posted November 2, 2011 I'm looking at a used Haltech E6K for $275 locally. Can I simply apply +12 volts to what I'm assuming is a Main power source and the switched power source and see if I can connect and read the haltech without any sensors hooked up? Is there any other way or is it simply a $275 gamble? Quote Link to comment Share on other sites More sharing options...
Meph Posted November 3, 2011 Share Posted November 3, 2011 I don't remember exactly, but if you hook up power and ground plus the accessory power it will turn on and you can query it. You need a dos based laptop to communicate or run dos box, its a little tricky to set up so its hard to tell if you just got the programming of dos box wrong or if its dead. I have a e6k that seemed to be a little finikie to me and reset when I turned the engine over. selling it for 100 is someone wants to try it, it communicates fine I just couldnt get the engine to start. Quote Link to comment Share on other sites More sharing options...
JSM Posted November 3, 2011 Author Share Posted November 3, 2011 Hey Meph, what kind of Computer were you running it on? When you say reset, it would wipe all your settings? Did you get another E6K? Was it these 3 of the flying lead portion of the harness? Quote Link to comment Share on other sites More sharing options...
