surpip Posted January 22, 2012 Share Posted January 22, 2012 If you use the T3 backing plate you will also need to use there strut tube as well, what axles do you plan on useing? Quote Link to comment Share on other sites More sharing options...
RB240zDET Posted January 22, 2012 Author Share Posted January 22, 2012 Could you not use the stock z32 backing plate? Quote Link to comment Share on other sites More sharing options...
surpip Posted January 22, 2012 Share Posted January 22, 2012 Yeah for the e-brake set up you use the stock Z32 backing plate, but to mount the hubs and evrything elce you need the T3 "backing plate" so this set up can mount to the stock LCA. you cant just use the T3 backing plate alone. Quote Link to comment Share on other sites More sharing options...
RB240zDET Posted January 22, 2012 Author Share Posted January 22, 2012 Yeah for the e-brake set up you use the stock Z32 backing plate, but to mount the hubs and evrything elce you need the T3 "backing plate" so this set up can mount to the stock LCA. you cant just use the T3 backing plate alone. Sounds good, this is all info for tybee as I have these parts and when he comes up here with my vented hood he will be picking up my spare 300zx z32 rear calipers and knuckles with ebrake and brake shield. Good info and much appreciated Surpip. Quote Link to comment Share on other sites More sharing options...
surpip Posted January 22, 2012 Share Posted January 22, 2012 No problem just don't want him getting his hopes up that he is going to be able to get away with only spending the $550 Quote Link to comment Share on other sites More sharing options...
Guest tybee260 Posted January 24, 2012 Share Posted January 24, 2012 Ha I did get my hopes up, so I will need the rear strut tubes as well? I was just about to pick up some ground control coilovers and tokico illuminas to use with section strut tubes Quote Link to comment Share on other sites More sharing options...
Guest tybee260 Posted January 24, 2012 Share Posted January 24, 2012 Also using the z32 hub will allow the use of Cv axles as well right? I have a r200 long nose with 280zx Turbo cv shafts....or would I need to use the cv's out of a z32. Not sure of the difference if there is any Quote Link to comment Share on other sites More sharing options...
surpip Posted January 24, 2012 Share Posted January 24, 2012 (edited) You would need to use the Z32 axles but i think you can get stub axles for the diff that can take the Z32 axle bolt pattern. Talking with T3 would be your best bet. Edited January 24, 2012 by surpip Quote Link to comment Share on other sites More sharing options...
RB240zDET Posted January 24, 2012 Author Share Posted January 24, 2012 Well I have the z32 axles as well... Quote Link to comment Share on other sites More sharing options...
