Watercooled Turbo
450HPZ
Where is the return from the turbo dumping into the coolant system?
My issue.. was the return would flow at the thermostat.. where the temp sensor was. The sensor got a false reading and picked up the HOT coolant that passed the turbo. My readings were off from the actual engine coolant temperature.
I was running Megasquirt and had my coolant sensor separate from the coolant gauge sensor. That's how i discovered the variance.
yes it ism I have it hooken to the ling that use to go to the throttle body, hmm thx
