Turbo Igniter required?
78zstyle
no-but you need some sort of power transistor to fire the coil.diyefi has 1 or you can use an old 4 pin gm hei module.I used the MS to fire the original turbo coil/ignitor assembly.The MS website has lots of wiring diagrams-problem is (to me) that the info is kind of spread out on the website.There is also a bosch ignitor that will work.
