Engine and tranny location& misc
I am working on a 72 240z w/ auto
I am installing a 90 5.0 w/ 5-speed
I am wondering since I had used fallen100's motor mounts(attached to frame)and he had installed the 95 mustang rack n pinion I cannot locate the enngine where he has. His mounts are about 4 inches behind the crossmember, mine (becouse of sterring shaft)will have to be located directly over the crossmember. This does pesent some problems(ie: must weld the mount instead of bolting; engine weight more forward) I know the engine will fit in that location, but will I have to mangle(cutting) the hump just to get the tranny to fit? I would love some info on where you guys have your engines located and where the stick from the tranny comes out. Also what is this I have been hearing about using a different gas tank. What year and why? (fittings?)
