New Frame mount design
alsil
Hey guys, I have revised the frame mount design for my car:newmotormountdrawing.jpg
this is to reenforce the frame rail, and to be a more solid mount. You will also have to add a 1/4" spacer to the bottom of the transmission mount to even up the angles. thought I'd share that with you guys, just in case you were going to try and use that design.
Thanks
They're not much different, but I COULD have used the heddmans I bought if I hadn't done the power conversion. If you are talking about the 5.0 headers, I don't think so. the collectors are too wide and contact the frame rails. The only way to make those kind fit is to raise the engine, and I wouldn't raise the engine anymore. I am only doing the 1/4" so that I get better crossmember clearence.
Thanks
AL
