letitsnow Posted June 8, 2012 Share Posted June 8, 2012 (edited) Are all the bins in the VE table around idle roughly the same? Have you set the injector opening time correctly? Edited June 8, 2012 by letitsnow Quote Link to comment Share on other sites More sharing options...
78zstyle Posted June 8, 2012 Author Share Posted June 8, 2012 Bins are the same around idle. I believe my opening time is correct i have 440 7mgte injectors .9 opening time Quote Link to comment Share on other sites More sharing options...
78zstyle Posted June 8, 2012 Author Share Posted June 8, 2012 Also.. Is 30 or so kpa normal at idle? Quote Link to comment Share on other sites More sharing options...
letitsnow Posted June 8, 2012 Share Posted June 8, 2012 (edited) I'd consider an upgrade to ms1e code even though you're running fuel only, it has some improvements other than spark capability. What wideband do you have so I can scale the log correctly? 30kpa is great, I idle around 32-35. Edited June 8, 2012 by letitsnow Quote Link to comment Share on other sites More sharing options...
78zstyle Posted June 8, 2012 Author Share Posted June 8, 2012 Lc 1 wideband.. Ill try the msns code tonight for fun Quote Link to comment Share on other sites More sharing options...
78zstyle Posted June 10, 2012 Author Share Posted June 10, 2012 So I put msns on, and it runs a LOT better. My idle still fluctuates a bit.. maybe 1-1.5 but that used to be like 4-5 afrs it would surge. Im going to hook up my turbo dist soon enough to utilize spark control. Much happier with my car now. Quote Link to comment Share on other sites More sharing options...
