Guest Anonymous Posted March 12, 2002 Share Posted March 12, 2002 Say i have a 302, and i want to put it in Z chassis. Which chassis is going to give the best profomance a 240Z, 260Z, or 280Z??or is there no diffrence Quote Link to comment Share on other sites More sharing options...
Guest bobs302z Posted March 13, 2002 Share Posted March 13, 2002 the 240&260 are lighter than the 280 (240 is 2400 and the 280 is 2700) there are several reasons for this doors, bumpers rear end etc. if you go with a 240 you have to change to a 280 or newer rear end ( r180 to a r200) there are many storys on this site about people blowing up the r180 I went with the 280 but have put older stile bumpers grill etc to make look like a 240 i think it is easyer to find that switching rear ends the more info you read from this site before you deside the better off you will be some body here has done it the wrong way before and lucky for us new comers has talked about so we dont make the same mistake GOOD LUCK Quote Link to comment Share on other sites More sharing options...
Guest ScaryFast Posted March 13, 2002 Share Posted March 13, 2002 when you say "replace the rear end", do you meen just the center section or everything? Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted March 15, 2002 Share Posted March 15, 2002 what he is talking about is changing the whole case and the half shafts i think. i am pretty sure the half shafts do not switch from 180 to 200 diffs.(not the same bolt patterns). i hope this helps Quote Link to comment Share on other sites More sharing options...
