SR20DET Oil Pick up problem
logr
No pics as I have dial up but I have had an oil pick up tube head break off twice so I thought a heads up would be in order. The early SR Red tops have a brace welded to the tube but Black tops have it welded to the head. The head of the pick up has broken off on 2 Red tops in my shop. There appeared to be no damage so I have attributed it to vibration until a better explanation comes along.
Easy fix is buying a newer pick up or welding a brace to the head of the pick up.
I no longer let an SR leave my shop without the fix as it is cheap insurance.
  • 4 months later...
This happened to my motor once as well, I rode #3 got chewed bad.
Also, some of the newer VE fwd oil pick ups, they have no brace at all.
Perhaps a better solution might be instead of adding a brace, welding completely around the head/tube joint, and the tube/flange joint
  • 2 months later...
