Zmanco Posted May 14, 2012 Share Posted May 14, 2012 A long time ago I had some rubber plugs that fit into brake hoses so that when you removed a caliper, you could quickly push the plug in to keep the rest of the fluid from draining out and having to deal with air in the M/C. I came across these at mcmaster http://www.mcmaster....y-plugs/=hir3ac which might work and now need to know what the ID is for braided brake hoses on S30 cars. FYI, I'm using the Toyota 4x4 up front and 240sx in the rear in case that affects the hose ID. I'm hoping someone has a hose that's not installed and can measure it. Quote Link to comment Share on other sites More sharing options...
