Early 260z L28et swap wiring issues
I got a lot of the stuff fixed, I'm a little confused,
I got this setup for the Fuel pump.
Bought a relay for it and wired it like this,
the blue/red stripe wire is the switch for the relay to power the pump.
the green wire goes straight to the pump. from both relay and connector,
the black/white wire is for a switched 12v, can I just splice it into the harness behind the ignition switch?
Thanks man
Is there anyway to know if the ecu is working?
I spliced everything to together to try and fire it up but I didn't get any spark or fuel, I used the harness on the ignition switch.
I know the pump work because i ran a wire from the battery to the pump to test it, there was a ruptured line and fuel sprayed out so I know it works.
I don't know if I need it be i'm missing a condenser, I think I may have an N/A coil.
