TheBlaiant Posted May 24, 2012 Author Share Posted May 24, 2012 I got a lot of the stuff fixed, I'm a little confused, I got this setup for the Fuel pump. Bought a relay for it and wired it like this, the blue/red stripe wire is the switch for the relay to power the pump. the green wire goes straight to the pump. from both relay and connector, the black/white wire is for a switched 12v, can I just splice it into the harness behind the ignition switch? Quote Link to comment Share on other sites More sharing options...
dexter72 Posted May 24, 2012 Share Posted May 24, 2012 Yes or find a switched 12v wire at the fuse box, might be a cleaner looking install. Quote Link to comment Share on other sites More sharing options...
TheBlaiant Posted May 24, 2012 Author Share Posted May 24, 2012 Thanks man Is there anyway to know if the ecu is working? I spliced everything to together to try and fire it up but I didn't get any spark or fuel, I used the harness on the ignition switch. I know the pump work because i ran a wire from the battery to the pump to test it, there was a ruptured line and fuel sprayed out so I know it works. I don't know if I need it be i'm missing a condenser, I think I may have an N/A coil. Quote Link to comment Share on other sites More sharing options...
