So how far off is my speedometer?
GreenState
I recently swapped the rear diff in my 4 spd 240z from the stock R180 to a STI R180 with 3.9 gears.
The service manual says the 4 spd has a 3.3 final drive.
I'm thinking the speedometer is reading a bit faster than I'm actually going. Am I correct, backwards, or just wrong?
Thanks.
Your speedomater should be reading about 18% fast now, assuming you have stock height tires.
You can get the correct plastic cog to go in your transmission to make it read appropriately. It is officially known as a "speedometer pinion gear" in Nissan speak. I believe you'd be looking for the white one (19 teeth).
This thread has some good info in it:
http://www.classiczcars.com/forums/thread6997.html
The Zhome page also has some good info:
http://www.zhome.com/ZCMnL/tech/R200.htm
For those finding this thread while searching, here's which gears you will need for various rear ends to make your speedometer read correctly:
3.336 : Yellow (16 tooth)
3.545 : Black (17 tooth)
3.7 : Blue (18 tooth?)
3.9 : White (19 tooth)
4.11 : Red (20 tooth?)
This eBay listing shows a yellow gear in the picture, but the description lists it as a 19 tooth gear. I would be sure to confirm with the seller that it is in fact a 19 tooth gear. It is listed for about $50+shipping.
Search tags:
speedometer
plastic cog
speedo drive cable
swapping ratios
spedo reading off
Edited by cockerstar
