Steering rack clearance
After installation, my small block Ford 289 clears ( oil pan is above ) the steering rack by an inch. I am wondering if others have had the same clearance? Is this enough clearance?
My SBC 350 damper is about a 1/2 inch above the steering rack on the JTR set back position in the 280 Z. I would say one inch clearance on your application is good with even wore out Ford engine mounts.You might want to lower it another 1/2 inch
