ESP-OFF Posted August 18, 2012 Share Posted August 18, 2012 Whatelse can I use other then the manual trans for my 2jz-gte swap. Figured I could use part of the driveshaft. Didn't know if I could use anything else since I have the whole car. Quote Link to comment Share on other sites More sharing options...
v8dats Posted August 25, 2012 Share Posted August 25, 2012 harness.. u need to make your own motor mounts. maybe you can do a suspension swap? lots of work tho Quote Link to comment Share on other sites More sharing options...
kaito Posted September 19, 2012 Share Posted September 19, 2012 I wouldnt do a suspension swap from a mk3. One, the suspension was designed for a heavy car and two, the rear subframe is notorious for cracking especially the 87 model. (ask me how I know). I might however try and retrofit the differential and halfshafts and maybe brakes if I really felt like playing on the bridgeport. I had a new friend show me his homebrew q45 diff swap and im certain that for less than $200 bucks I can do the same thing. He had the q45 shafts shortened at moser for $150!!! and then just used some aluminum to make hub adapters with hand tools, notched the rear a-arm bar, and fabbed up a simple mount much like the R/T for the front of the diff and called it a day!!! Sorry for the rambling btw. Or you could 2jz the mk3!! Quote Link to comment Share on other sites More sharing options...
redleg Posted October 9, 2012 Share Posted October 9, 2012 (edited) You can not use a factory r154 transmission to bolt up to your 2jz.. You need to obtain a 1jz bell housing and install that on the r154 trans. Then it will bolt up. Edited October 9, 2012 by redleg Quote Link to comment Share on other sites More sharing options...
