Guest Anonymous Posted November 17, 2000 Share Posted November 17, 2000 Which one is best for a turbo engine and how do you tell them apart? ------------------ Morgan http://z31.com/~morgan/s30 http://carfiche.com Quote Link to comment Share on other sites More sharing options...
Drax240z Posted November 17, 2000 Share Posted November 17, 2000 Well I'm a little uncertain on this one. The 81-83 intakes all have a ton of crap on them... stuff you don't need if going SDS, etc. So they are going to look really cluttered. The earlier 75-76 manifold I've heard are the desireable ones since they have less stuff on top. BUT, I do recall reading that the intake runners on the turbo intake are 2mm(?) larger each... Its a bit more work, but I am planning on grinding my 82 turbo intake down and getting the holes welded in once I know how many I need. At least I can be sure I have the "best" intake runners then. ------------------ "Gimme Fuel, Gimme Fire, Gimme that which I desire" -Metallica Drax240z 1972 240z - L28TURBO transplant on the way! http://members.xoom.com/r_lewis/datsun.html Quote Link to comment Share on other sites More sharing options...
Guest scca Posted November 18, 2000 Share Posted November 18, 2000 i have both manifold but havent decided which to use yet..i will measure and see if one is bigger and use it. thinking the same.. maybe the 82 manifold and spend a ton of time cleaning it and then have it polished. i have a spare 82 one and i think a spare 75 one. Morgan.. didnt have time to check out the head - going to seattle for the weekend will check it on monday and let you know..the motors at a friends in storage so not in the shop here Mike Quote Link to comment Share on other sites More sharing options...
