0-60 in 7flat or faster, how much $$$?
I run 0-60 in 6.2 seconds with a NA L28 in a 1982 280zx 2+2, and my 1/4 mile is 15.0 at 97 mph. These numbers were spit out by my G-Tech, not by a stop watch, so I trust their accuracy. The only difference is that I have a 5 speed, but 7 secs is still reasonable for you I think...
First, run premium gas for at least a tank before trying this...knocking is no fun!!!
ok...here's what I've done, and all I've done (performance wise)...
1) Timing advance (28 degrees BTDC, massive change there over the stock 8 degrees)
2) Valve clearances set to 0.010" hot across the board.
3) Muffler swap (glasspack) (I have no idea if this made a difference)
4) (Basic stuff) Spark plugs, wires, distributor cap, rotor. Won't make a difference unless yours are bad.
Total cost: you'll need a valve cover gasket, $11 or so, and a few hours...
[This message has been edited by SamH (edited November 18, 2000).]
