Ignition Timing Way too Advanced...
TieFighter88
By "breaker plate" I mean the movable part where the stator mounts.
You should be able to grab it and move it a bit and the spring tension inside the advance mechanism should return it.
Also inspect around the periphery of the plate and see if you can see broken parts or a ball bearing ball that has fallen out.
  On 9/23/2012 at 1:00 AM, Tony D said:
So PLEASE understand this sits is NOT devoted to mechanical noobs, neophytes, or that ilk.
I fail to see this rhetoric posted anywhere by the site owners and moderators or in the rules linked below.
http://forums.hybridz.org/index.php?app=forums&module=extras&section=boardrules
