Anyone looked at the new GM straight 6?
BLKMGK
Crossflow head, aluminum block, aluminum head (weighs 470 or so lbs), PM rods, 4valves, DOHC with VVT on the exhaust, cast "header", and the ECU is mounted ON the engine! HP is supposed to be a bit under 300 but racing versions have produced nearly 500! This puppy sounds NICE and might be a darned good swap once a few end up in wrecking yards.
Guest Speaker
this will also most likely be the engine that goes into the 2004+ Camaro and Firebird
the corvette will be getting its own brand-name... Corvette... and the Camaro will be a go-fast-for-cheap version of the Corvette...
thats what i've read anyway... GM announced it..
the Corvette Camaro? hmmm
better than taking the car away completely...
they most likely didn't like how the Z28 was so close in performance to the C5...
still 270hp isn't bad if they can keep the weight down...
