Guest Anonymous Posted March 9, 2001 Share Posted March 9, 2001 so this is my plan for the 240z, considering im only 16, and limited knowledge about cars, but a steady income (god bless webdesign) anyways, here it goes if you could give me your feedback ideas, opinions experiences you'd be doing me a great favor to a 16 yr old teaching himself cars. 73' 240z prod. 10/72 -82ZXT rebuild stock p90 head -something like a t3/t4 turbo (i have no idea what that means) some intercooler SDS... that is totally stripped engine less, everything is torn out. i have no idea what to do next....buy an old head? buy an old ZX and rip the engine out, where do i rebuild the engine? transmission!!! rear end!! help...overwhelmed.. -Chase Quote Link to comment Share on other sites More sharing options...
Guest Fast Frog Posted March 9, 2001 Share Posted March 9, 2001 Your 82 ZXT engine is great for turbocharging! I had that same engine in my setup with a bigger T4 turbo and ran 15-18lbs of boost with a proper fuel delivery system. The P90 head is a turbo head-larger combustion chambers. If you don't go turbo, then you'll want to change heads cause the P90 gives you only 7.4 to 1 comp ratio. Some guys are using 240Z "E" heads and even 280Z "N" heads. The ZXT engine will fit and work in your 240 but you'll have to use your stock 240 intake manifold with the Mikuni carbs. You'll have to retune your carbs cause you you're going from 146 cubic inches to 168 cu in. If you want to go turbo, there's more hardware to buy, particularily an up graded fuel delivery system. Many of the members of this forum have great turbo systems they've installed on their 240, 260, 280 and 280ZX cars. Your about to be innundated with ideas and great turbo advise!! Enjoy!! Rick [This message has been edited by Fast Frog (edited March 09, 2001).] Quote Link to comment Share on other sites More sharing options...
