350 EXTREAM
ok i have a 350 bored 60 over with a blue streek cam so big it wont idle under 1500rpm andso i wana put dubble hum heads on it and shave them 10 thousenths and a 4 speed muncy in my 82 280zx 5 speed how hard is this guna be and what info do i kneed to know and will 600hp rip the z apart should i reinforce it? thanx justin
On a second Gen it won't hurt the thing structurally, but with 600 hp you want to probably put a cage in the car, they're heavier than the first Gen Z's, but 600hp is fast enough to require a cage anyway. If its going to see freeway use though, you'd better look for a 5/6 sp trans with overdrive otherwise 4th gear will be real busy on the freeway.
It should make a great swap, if the smog laws were different here, I'd have no issue using the zx, its a bit more plush and sound, the 240 is lean and just a raw sportscar IMHO with the V8 in it, sure it can be made up plusher, but it still is just a bar brawler compared to the luxury of the later Z's. At times, I wouldn't mind having that luxury.. icon_biggrin.gif
Good luck,
Lone
[ October 20, 2001: Message edited by: lonehdrider ]
