Better priced headgasket
I am doing research on how well a 91mm headgasket would sell if it were priced under$150, free delivery, and 30-day replacement warranty? Gasket could be stock thickness, 1mm, or 2mm of varying bore sizes. I am no longer satisfied with the 91mm metal gasket that is known to leak. The price is also out of line. $200 plus. It has no warranty. If it leaks, you are stuck. No matter what you do to prepare for the install, if it leaks, it is attributed to improper installation. I need feed back. If enough of you out there respond, I may go ahead and start production. I could also make gaskets for 4 cylinder, v-6 applications, and others.
Thanks
Nikko Holguin
TCF Racing
713-910-8826 if no answer,
call 281-488-5488 and ask for Kyle
