EFI to Carb Conversion
AZGhost
On 11/20/2012 at 7:22 PM, AZGhost said:
So asking around at some Z shops, seems this is easier than I thought. Pull cable from ECU, pull ECU out, and then cable harness from ECU comes out. Whatever is attached to the cable harness can go. Piece of cake....
@AZGhost
did you ever find a solution to the wiring problems after you removed the EFI Harness?
i've kinda stumbled upon this problem and am currently trying to figure it out.
did the advice given to you by others work out?
