Datsun660z Posted March 27, 2001 Share Posted March 27, 2001 Please help I have A 1976 280z that has been changed to 260z carbs the ones with the flat tops. When it is below 50 degrees outside my car wont start unless I prime the carbs with gas, both chokes come on when I pull the lever back. Please help. Thank You. Jon Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted March 28, 2001 Share Posted March 28, 2001 Jon, That is a drivability problem & could be just about anything since the car is not original...only you know its set up best. It could be anything from improper ignition timing to spark plugs/plug wires, coil, carb choke, fuel pump, to a relay that acts up under the stress of the cold(?). Give more details; when it is above 50F after it starts does it spit/sputter or does it ever backfire? When it is below 50F as you turn the engine over is it a slow turn or does the engine turn over fast/normal. If its a fast & even turn it means you have good compression usually & a strong starter. The three things that keeps an internal combustion eng.from running is the lack of: 1) Air 2) Fuel 3) Electricity (Ignition) or a combination of the two/three. Your best bet is to obtain a Service Manual & follow the flowchart. I would first confirm your ignitions spark is strong. Confirm the choke mechanism is functioning correctly, & confirm your ignition timing is set properly. I'm no carb specialist but I do have a 260 service manual. If you are having carb prob's then the flow chart for checking the carb is: Trouble Diagnosis: 1)Eng.Does not start a)Overflow b)No fuel feed to the engine c)Improper Idling Adjustment d)Malfunction of suction piston a)Overflow * Float Leaking...Replace Carb Assembly * Dirty Needle valve Seat...Clean Valve Seat * Loose Needle Valve...Retighten * Scratches/Worn Needle Vlv.Seat...Refit/Rpl * Fuel Pump Drawing in Air...Repair Pump b)Nor Fuel Fed to the Engine * Check Pump for proper operation * Check Fuel Lines * Check Needle Valve c)Improper Idling Adjustment * Readjust appropiriately according to spec's d)Malfunction of Suction Piston * Sticky due to deformation...Rpl Carb Assem. * Bent Jet Needle...Rpl Carb Assem. * Bent Plunger Rod...Rplace As I said earlier...it could be just about anything/hope some of this helped! Kevin, (Yes, Still an Inliner) Quote Link to comment Share on other sites More sharing options...
