EZ Wiring Harness Brake Light wires???
dpuma8
I do not understand how to wire up the brake lights along with the running lights with the EZ wiring kit.  The kit has a brown wire labeled Tail Park Lights and off of the brown wire is the connection to the license plate light.  To accomodate the rear side markers, I soldered extra wires into my brown wire so that those will be connected.
Now the problem is the only wire I have left to do is the Orange Third Brake Light wire.  Where is the brake light wires in the harness I need to plug in?  Am I adding a second wire off of the Third Brake light and then connecting those to my rear brake lights?  How does this work?
You can wire the third brake light wire to the brake light bulbs in the taillight assy and connect the other end to the brake light switch on the brake pedal. You might need to play with a test light to find the hot wires but its not too much of a pain.
