Guest Anonymous Posted July 10, 2001 Share Posted July 10, 2001 Ok I have a 71 240 Z I have pulled out the engine and now am putting it back in. I have the crank mark pointing up, The cam sprocket has a 1, 2, 3, on the outer ring 1 am pointing the 1 up also when i put it on the valver are hitting the piston.. Does the position of the marks sound correct< both up?> AND i had to have the head milled due to it was leaking out the sides, This could be it but wanted to make sure i was installing the timming chain righ?? thx for helping Quote Link to comment Share on other sites More sharing options...
Kevin Shasteen Posted July 10, 2001 Share Posted July 10, 2001 Well Redline...for your first post-this is a goodie! I've never rebuilt a Datsun engine but I have a few books on them. How much was the head milled? From what I've read-The bright chain link must align with the cam-sprocket timing mark that agrees with the dowel hole which engages the cam-drive dowel and make sure the cam sprocket doesnt turn while you're slipping the chain downward/over the crank sprocket for assembly. Nother-words; as you've mentioned-there are three of them; if you have chosen to use the #1 dowel hole then you should also likewise use the #1 timing mark...the same goes for #2. If you've chosen the #2 mark-then the #2 dowel hole must also be used...ect,ect same goes for the #3. If I've missed something-then maybe someone who has actually rebuilt the Datsun I6 can chime in & help. Kevin, (Yea,Still an Inliner) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 10, 2001 Share Posted July 10, 2001 Ok it took me a little bit but i was thinking that i need to line up the dowl on the camshaft to the top not the mark on the timming chain sproket... As i look closer on the sproket their si 3 holes on the inner part of the sproket that would line up #1 to the top as the dowl is at athe top.. thx for your feedback, as far as how far for the milling i am not sure it needed to be done bad u could see the blowby,but the machine shop i took it to just did it and handed it back i will re try to adjust this and let u know what i found. thx again,, P.S. 1 day I will have a V8 11 second car in my garage a 11 second Z CAR, sigh 1 day Quote Link to comment Share on other sites More sharing options...
