Guest Anonymous Posted October 2, 2001 Share Posted October 2, 2001 I'm putting an 81 L28 in my 71 240z. Only problem is I don't have a distributor except for my old 240z one, and I can't find any zcar distributors in any of the junkyards around here. Does anyone know if I could just use a maxima distributor? Also, they have E12-93 ignition modules on the side, from what I've seen in junkyards. My engine will be carbureted and I've heard these ignition modules use a bunch of sensors and an ECM that my car won't have. Should I, could I switch the ignition module to an E12-80. I've seen them on datsun's all over the place. Will this work? thanks Rob Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 2, 2001 Share Posted October 2, 2001 You would like the results of what I did. I run MSD6A box, wires, and coil......with a Elec. pickup distributor of a 75 (dual pickup). Works very well, never misses a lick and I can spin 7200 rpm without pulsing. jake Quote Link to comment Share on other sites More sharing options...
GrayZee Posted October 2, 2001 Share Posted October 2, 2001 Yeah the 81-84maxima distributor will work. If I remember right, one wire goes to the -coil terminal and the other wire to the +terminal. However the later model distributors have a plug at the bottom of the module, you don't need it, but I'm not sure what will happen if you leave it un-connected. Although I know that if later you can get your hands on a earlier module, it'll fit on the newer distributor. Quote Link to comment Share on other sites More sharing options...
