cameraobsess Posted October 30, 2001 Share Posted October 30, 2001 ok im putting in an engine from a 1980 280zx 2+2 and i am not sure if im going to keep the fuel injection or the stoc carbs from the 240z (1972) i was just wondering whats easyer and what i would have to change for one or the other. can anyone tell me what the the good points are and what the bad ones are about both. thanks Julius Quote Link to comment Share on other sites More sharing options...
jeromio Posted October 30, 2001 Share Posted October 30, 2001 EFI would make for a much nicer daily driver. But, it will be much harder to setup. You'd need to wire in the ECU and all the sensors. You'd small auxilary surge tank. If the engine sat for while you may have a few injectors to replace ($$). The alternative is to just bolt up your carbs. Thankfully, Nissan made all the L28 heads backwards compatible with the older intakes. You will need an electric fuel pump since the Head on the 80 engine won't have the hole for the mechanical one. Other than that, you're left with the standard fiddling with the carbs... Quote Link to comment Share on other sites More sharing options...
