Domzs Posted May 8, 2013 Share Posted May 8, 2013 Check the wire that goes to your coil + to see if it has power when key off . If it does then someone hooked it up wrong . Need to download FSM . Quote Link to comment Share on other sites More sharing options...
MudflapE Posted May 9, 2013 Author Share Posted May 9, 2013 Ok I'll check it tomorrow, also gonna try to adjust carb. Thanks Quote Link to comment Share on other sites More sharing options...
MudflapE Posted May 12, 2013 Author Share Posted May 12, 2013 So here is what is going on with my car.. Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 12, 2013 Share Posted May 12, 2013 So you are able to kill the motor by turning the key off , what did you do ? You either have a big vac. leak or throttle out of adjustment . Do you have the choke setup ? Quote Link to comment Share on other sites More sharing options...
MudflapE Posted May 12, 2013 Author Share Posted May 12, 2013 Actually I didn’t fix that, just wanted to show what is going on with it Quote Link to comment Share on other sites More sharing options...
Domzs Posted May 12, 2013 Share Posted May 12, 2013 Check your throttle stop setting ( make sure it's not set too high/open too much ) , cable/linkages ( for binding ) , choke operation , vac. leak . Need to check the coil power as stated in earlier post . Quote Link to comment Share on other sites More sharing options...
