Guest ywg396 Posted December 27, 2001 Share Posted December 27, 2001 Aside from the obvious, i.e.turbos, pistons,ecu eprom,injectors, exhaust manifolds... what would it take to convert a non-turbo vg30de to a turbo vg30det or vg30dett The dohc, variable valve timing, and direct ignition look the same. I have a line on a complete engine/harness/ecu for a non turbo Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 22, 2002 Share Posted January 22, 2002 as far as I know the VG30DE has a higher comp. ratio than the VG30DE-TT other than that the TT's only other big diff. are the dual T-25 turbounits witch probably makes it slightly larger than the non-turbo model. I think thats it. Quote Link to comment Share on other sites More sharing options...
