Removing old paint from Polyurethane skirts
Zlockbox
Apparently the previous owner sprayed the front air dam and the side skirts with non flexible paint. Will taking walnut shells through a sand blaster get this incompatible paint off? I am thinking so I just wanted to see if anyone has tried this before.
That would probably work but you may need something a little more aggressive like glass since the base is somewhat soft. Try it and see. I would use some pretty coarse sandpaper on a powered tool to get 3/4 of the paint/primer off first. Sanding first just makes the process faster in most cases.
