Guest Anonymous Posted March 22, 2002 Share Posted March 22, 2002 Hope someone can help me. I'm putting my cam kit onto my head and ran into a geometry problem, maybe. Here it goes, everything on the rocker arm wipe is centered and looks good. My lash pad is slightly offset closer to the cam but is not too bad. Should I be concerned if its off by a little meaning not exactly centered or should I get thicker lash pads to center the wipes right in the center? Thanks Quote Link to comment Share on other sites More sharing options...
Guest V8wannabe Posted March 23, 2002 Share Posted March 23, 2002 If it still on the lash pad and not "running off" you should be ok, besides changing the LP thickness will change the wipe on the rocker arm. Quote Link to comment Share on other sites More sharing options...
