bigbreak_2000 Posted June 27, 2013 Share Posted June 27, 2013 I'm looking for alternatives to the CDI (MSD) setup for my engine. Need to be able to support ignition pulses for speeds up to 7.6k rpms. Any auggestions on a reliable coil and igniter setup? Perhaps someone here have upgraded there engine to run using a basic coil, or COP/coil on plugs or coil packs, let me know which plug wires and coils you're using. I'm currently using a siingle channel igniter (adaptronics igniter and adaptronics ECU), MASD6 box, MSD Blaster2 coil, MSD tach adapter, NGK perf plg wires. Someone suggested to me that I could perhaps just delete the MSD parts and add a coil from a 2004 GMC Yukon which apparantly can support up to 8k rpms. In the rally racing circles also the 1984 golf gti igniter is considered a good ICM. I can also get my hands on a low cost set of COPs from a toyota celica gts/matrix/pontiac vibe but not sure if these will fit. The ECU support 3 ignition outputs which I could simply wire in pairs to the IGT (ignition trigger) inputs on these coils (they dont require seperate ignitors). Quote Link to comment Share on other sites More sharing options...
