Guest Anonymous Posted April 2, 2002 Share Posted April 2, 2002 i went to the good machine shop here in town and got some quotes and i just wanted to run them by u guys the quote was 500 dollars to do the following valve job bore engine .020 over hot tank and turn the crank can u guys think of anything else?? or would i be better off taking it to a town a little bigger to get a better price. thanks a lot dave Quote Link to comment Share on other sites More sharing options...
katman Posted April 2, 2002 Share Posted April 2, 2002 First off why stop at 0.020 over? That would require an aftermarket piston (as opposed to a standard factory oversize), and if you're gonna bore it doesn't cost any more to go +0.040 or +0.080. Which block is this? $500 bucks is cheap to do all that, and you will absolutely positively get cheap workmanship. You are rebuilding the engine because of what? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 2, 2002 Share Posted April 2, 2002 with .020 i will still have block later on that still has some meat left into it. the motor is a f54 turbo block. i am rebuilding it because "I have the need, the need for forged pistons" so i was going to go .020 over so that i can have nice new thatching on the cynlider walls to start my project off with. I will be running a t3/t4 turbo thanks to z gad, with forged rods and pistons. thanks dave Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 7, 2002 Share Posted April 7, 2002 Oscar... people have bored 3mm over (.120) an f54 block (i.e. 3.1 stroker) just fine, ran 500+ hp just fine. That's the clear limit though. And that's the only recommended block for this. Take a look at James' (240turbo) setup if you want verification. I'd say go for it man. I feel the need.. the need to save money and draw the line somewhere. But if I'm making 350 hp at the crank I could easily fry a piston, even preventing det. with huge spearco and water inj. If I do fry one, I'll get a set of 89mm bore JE's and bore .120 over. Even without a stroker crank that's another 12 cubes.. another 30 horse with a full turbo setup. Hell ya! Lets just say I won't be *too* upset if I fry a piston good luck w/ your setup -980mak Quote Link to comment Share on other sites More sharing options...
