Guest Anonymous Posted June 26, 2002 Share Posted June 26, 2002 Ok guys give me alittle input.. i not sure if these things will fit on my 280zx or not. Any changes or mods. or donts. JUST let me knew:)!! THANKS GUYS!!! -Ark P.S. this is all at summitracing.com so i have not looked at my motorsport mag yet. im out of town and got bored. many of time:) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 26, 2002 Share Posted June 26, 2002 HAHAHAHAHAHHAHAHAH i forgot the list:) WHOOPS! Part # Item Price Qty Price Delete -------------------------------------------------------------------------------- CRT-P4594 Universal, 7 psi, street/strip style, electric fuel pump $56.95 $56.95 FLX-4136 12 in. x 3 1/2 in. x 3/4 in., two pass, 4,500 GVW, fuel cooler $39.95 $39.95 HLY-26-504 1 1/2 in. fuel pressure gauge: 0-15 psi, liquid filled, black with white digits, mechanical $38.69 $38.69 MSD-5900 Blaster Ignition $79.95 $79.95 MSD-8252 MSD HVC Blaster coil $109.95 $109.95 MSD-8777 1 to 5 degree retard module kit $23.95 $23.95 SUM-G4902 12 in. diameter, 3 in. deep, black, polypropylene, straight blade, Summit electric cooling fan kit $69.99 $69.99 TNW-13080 Universal, for use on EFI-equipped vehicles, 25 to 100 HP adjustable, EFI Power Wing Nozzle, nitrous oxide kit $448.00 $448.00 -------------------------------------------------------------------------------- SubTotal: $867.43 Quote Link to comment Share on other sites More sharing options...
Guest Aaron Posted June 27, 2002 Share Posted June 27, 2002 I you are still running the factory EFI, then the stock fuel pump/regulator runs at 20-30 PSI if memory serves. If you are increasing the HP, you will need even more than that. I finished reading your list. If the fuel pump listed is to feed the NOS, then check the manufacturer to see what pressure and flow you will need to support the kit. Quote Link to comment Share on other sites More sharing options...
SHANE Posted June 27, 2002 Share Posted June 27, 2002 make sure you go with NITROUS EXPRESS!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
