No Power, Red spark at the coil.
When i took my 240 out on the road it had no power at all, it struggled to get to 50mph. I took it back to my house and was checking it over to find what could be the problem. I took the ignition wire coming from the coil to the distributor cap off and held it a little bit above ground and then cranked the engine over. I noticed the spark was red. Thinking that it would've been the coil I went and bought a MSD blaster coil, installed it and still the red spark. If someone could tell me what else might cause this problem I would really appreciate it. It has a 81 maxima distributor in it.
Thanks
Lance
When was the last time the car was tuned up. From what little info you have given I would look at the fuel filter. May be clogged. Start there. Let us know a little more after that.
John
