turbo triple weber setup
Guest fly yellow
Guest fly yellow
i was curious about this idea so i did some research that some one might find interesting i found a site that sells hats that affix to dcoe's http://www.mazdaracing.com/carbs.htm the hats are a little pricey but this would be a pricey setup i would consider it if i could get the triples for a good price and if i could make my own hats but i just thought it was a cool idea
There are better ways to go with individual throttle plates than blow-through DCOE's (or equivilant Solex, Delloroto, Mikuni), by using TWM-type throttle bodies that bolt up to the triple carb manifold, then use a plenum shared by all six throttle plates. Corky Bell had such a plenum available as a "Cartech" part from a complex Weber blow-through set up. I bought one separately from them about 8yrs ago so I don't know if it's still available.
It has "Intercooled Turbo" cast into the top of the plenum. DAW
