Guest bigjim240z Posted September 25, 2002 Share Posted September 25, 2002 here is what im thinking..f54 block, flat top pistons, ported n42 head, isky .480 lift cam with 280 duration, su carbs with sm needles, motorsport header w/ 2.5 exaust and flowmaster. what kinda horse power will this make? with 3.90 gears and a 5 speed in a 240 will this spank a 5.0? another combo i thought about is an f54 block bore 120 thou, nissan z24 truck pisons, 240 rods, l28 crank, and same as everything else above?..is this a good combo?..or should i just use a v8? thanks for any help. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 26, 2002 Share Posted September 26, 2002 If you go with the stroker engine, I would recommend finding either a set of Weber 45mm DCOE's or better yet, a set of Mikuni 44PHH carbs. I feel that the SU's are the best choice for a mild engine, but that engine you are building will require more airflow and would benefit greatly from the triples. Personally, I would pony up the dough for a set of forged pistons in 88mm (0.080 over). You have "only a 3.0", but you won't have any problems with the block. I also would use a cam with a bit more lift and leave the duration the same. Mike Quote Link to comment Share on other sites More sharing options...
Dan Baldwin Posted September 26, 2002 Share Posted September 26, 2002 Check out the "3x2 carbs installed" post below, details on 235rwhp 3.1 liter are near the bottom. You're on the right track, but you'll want KA24E pistons, not z24, for a decent compression ratio. Spanking 5.0s should NOT be a problem. Hp with 280/480 cam and 1 3/4" SUs, maybe 200 rwhp? Quote Link to comment Share on other sites More sharing options...
Guest 280Tom'z Posted September 27, 2002 Share Posted September 27, 2002 i have seen a z run 12's on SU's so if ya got them keep them and put in bigger needles and make a stroker one of two ways 1700$$$ for the MSA 3.1 kit (really good chioce) or make a 2.9 with a L28det crank and stock rods. Quote Link to comment Share on other sites More sharing options...
Guest bigjim240z Posted September 29, 2002 Share Posted September 29, 2002 ok screw it..you know the old saying there is no replacment for displacment?...well there is..a big ass turbo!..just bought a turbo car and am swaping to turbo. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 29, 2002 Share Posted September 29, 2002 my dad has a fairly mild carby L28 making 100rwkw just a cam, blue printed, port & polish, SU carbs, better pistons, headers, etc.. pretty run of the mill the next upgrade he was looking at is basically what i'd call a Monster NA L28 Motec computer, multiple throttle bodies, fairly wild cam, reforged pistons, bored out, etc that was a nice lil equation for about 300rwhp if i remember correctly dad then decided he didnt want to spend a further 12k on his zed tho but yeah, thats my definition of a monster NA setup his current carby setup is good for some fun tho - its extremely torquey and is like a bullet off the line (dads upgraded pretty much everything on the car as well) I'm still faster but Quote Link to comment Share on other sites More sharing options...
