stock 2.4 vs stock 2.8
Tim240z
Guest norm[T12SDSUD]
Yeah its a drop in part but if you rnmy setup you'll need to clearance the bottom of the bores and the sides of the block. Its no big deal but it needs to be done.You can do that with a drill and a grind stone.
Also you need to bend the metal piece covering the ventilation hole in the #1 cylinder.
Also you need to shave the pistons .015" and use two headgaskets.
LAter,norm
