280zzzzz Posted May 20, 2014 Share Posted May 20, 2014 I've sectioned my struts for GC coilovers and Koni dampers, rebuilt stock rebuilt calipers - Looking for suggestions re connection of braided stainless connectors. On the front the bracket between hard lines and hose was removed (was located right at the area of the strut that was removed). At the rear the bracket was retained, but the stock length SS line creates too sharp of a bend. What have you'all done with these lines? I think I've seen (JMortenson?) rerouted, using a bulkhead fitting through the inner fender - nice, but are there simpler solutions? Thanks for your input. mel Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted May 20, 2014 Share Posted May 20, 2014 I ran without a bracket on the front for years and never had problems. But it always bothered me. So I found some brackets and had them welded on. A year later I went to AZC brakes ((which don't use the dang bracket) so I'm back to going without one. I think you will be ok to neglect it. I have run stock lines and stainles lines in the rear and had no trouble with the length. Mock it up and see if the line is gonna rub on anything, then let 'er rip! Quote Link to comment Share on other sites More sharing options...
280zzzzz Posted May 20, 2014 Author Share Posted May 20, 2014 Thanks for the response - These projects are a Never Ending Evolution - I'll get some longer SS lines and make them work. Quote Link to comment Share on other sites More sharing options...
280zzzzz Posted May 21, 2014 Author Share Posted May 21, 2014 Thanks - maybe I'm overthinking it - I'll get some longer SS lines and bolt it back together - Cheers Quote Link to comment Share on other sites More sharing options...
Dat260Z Posted May 21, 2014 Share Posted May 21, 2014 What Koni inserts are you running ? 86411220 sport? Have any issues with fitment in the 280 strut tube. Quote Link to comment Share on other sites More sharing options...
