Headlight issues
You didn't mention what year Z you have but if the highbeams and running lights work, you have a grounding problem.
You can try cleaning the contacts in the switch, if that doesn't work you may have to add a ground wire to your headlight circuit.
Check the headlight wiring diagram and add the ground wire just before the headlight ground is split into two, that way you provide a new ground for both headlights.
I did this on my 74 260Z 3 years ago, lights still work like a charm.
