Guest smoov280zx Posted January 8, 2003 Share Posted January 8, 2003 Holy S#^t! I bought an n47 today for a flattop buildup. It had a cylinder head temp sensor on the side, which threw me. Brandon said it was probably a maxima n47. Ran outside, cleaned the chambers off with carb cleaner and a shop towel, it's just like the p-series with the heart-shaped combustion squish dohicky! Oh yeah, I measured the valves too. It's already got the 280 valves! Geez, i can't believe the luck. The head is in awesome shape and i got it plus the intake and exhaust manifolds for fitty bucks. After a soak, i going to put it on my new bottom end. I would really appreciate some recommendations on the head gasket thickness. This things made for a 2.4, so i'm thinkin a 2mm would probably be a good idea. Any thoughts or if anyone knows what compression this would yield on a flattop f54, I would really appreciate it. (damn this rulez! ) Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted January 9, 2003 Share Posted January 9, 2003 Sounds good. There are three Maxima's at my local pick and pull with N47 heads on them. I would go grab all of them if some one said I should. If I could sell them for anything. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 9, 2003 Share Posted January 9, 2003 What year was the car that the head came off of? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 15, 2003 Share Posted January 15, 2003 hear we go (i hope not)not all are 2.4 some are 2.8 (have had 3 2.8 cars)the cc chamber is bigger in the 2.8 do you truly know its off a 2.4??? is the EXT round? Quote Link to comment Share on other sites More sharing options...
DAW Posted January 15, 2003 Share Posted January 15, 2003 It's probably got the 280Z ex valves, but not the intakes. I'd bet on 42mm intakes vs 44mm (L28). Regardless, you've got a good thing in that head, but if it's stock Maxima L24E you'll want to get rid of the cam and the intake valve springs. Just use any non-Maxima L6 intake valve springs and a drilled Zcar (or ZX) na cam. If you decide to go with the 44mm intake valves, any '75-'78 280Z head is a good source. DAW Quote Link to comment Share on other sites More sharing options...
