Guest JAMIE T Posted April 12, 2001 Share Posted April 12, 2001 Well, I found a complete engine, no harness or ECM. Cheap-$450. For that price, I am just going to buy it and just lower it in place and see what happens from there. The engine is a 2000 model and has a casting date of 9/99. It was a new car take out, dealer said "It had a noise". Don't know the culprit but it is so new that it doesn't have hardly any soot/carbon in the exhaust ports, and the oil is still golden colored. It was taken from a car that was in the showroom. So even the with the $450 purchase price, I could rebuild the engine and still be ahead. The worst I think it could be is a lifter tapping or a rod knocking, probably with only a few hours run time, there can't be but so much damage. I should be picking up my Z this Saterday, after that, I will be scouring the yards for a 2.8 V6 T5 bell housing and a trans. This might be dumb question, but do all of the T5's have the same bolt pattern were they bolt to the bell housing? I have an older one out of a mustang. The engine was wierd looking with two different colored valve covers, one is silver and one is black? I guess they did not want to waste the pretty silver paint on a cover that was covered up. I guess by now you have realzed that I am not going to put the Vorteched 302 in my Z. With the Vortech I would have to run the 87-93 style intake which is going to be a tight fit(My Vortech intake is taller than stock 5.0) So for the money I can get for my combination on the black market, I can fool around with the Northstar for a long time And I think you for your support, Jamie Quote Link to comment Share on other sites More sharing options...
jimzdat Posted April 12, 2001 Share Posted April 12, 2001 Jamie--I have seen a couple of Northstar motors with "a funny noise"--first things you want to check are all the bearings (yes, I'm staing the obvious) but then look at the cam assembly; they had a problem for awhile with cams that would wear prematurely and cause odd noises Jim Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted April 13, 2001 Share Posted April 13, 2001 it might be hydralic cam followers -when motor runs for a while it might go away. Quote Link to comment Share on other sites More sharing options...
