Think I Am On To Something
Scottie-GNZ
Its somtimes amazing how much you can learn about something just trying to track down 1 little problem, isn't it?
Sounds like you are on the warpath scottie. Good luck to you. Let us know how you're intake temps differ across the NPR and the air-water when you get it setup. I'm interested in knowing. icon_smile.gif
Scottie -
I certainly don't want to be held responsible for blowing your motor up (i.e., try this at your own risk icon_wink.gif), but you could try just disconnecting the knock sensor for a run and see if your problem goes away. As long as you have confidence in your base calibration, and are certain that the timing didn't _need_ to be pulled for some reason, and you are running enough octane, this shouldn't be a problem. I'm pretty sure that the sensor failure detection for the knock sensor is almost non-existant, so the controller should think everything is fine.
(Oops - just noticed that Blkmgk already suggested this - I still think it's a good idea, though...)
[ April 27, 2001: Message edited by: TimZ ]
You mentioned you might be loosing boost, hmm I have a thought for testing that. To actually test a turbo system for leaks is usually hard. I plan to get an adapter and use the air compressor to pressurize the entire intake system to about 20 psi. I will then use soapy water to detect leaks.
Just a thought I had, our company air tests alot of pressure vessels this way.
And rev it up a few times and have the biggest spud gun you've ever seen!
"News today. A neighbor was killed today by a spud projectile shot from a Datsun Z.. News at 11:00."
Lone
I have to put any serious testing on hold for a short while as my BFG DRs have struck a chord with me, err, have the CORDS showing icon_biggrin.gif. I might try some 3rd gear acceleration testing but I will have to ease into the boost. All I have laying around are some 215/60HR15s and they are only good for holding the car up or cruising down the hi-way.
Tim, I was tempted to disconnect the knock sensor Wed night but I did not have the b*lls and luckily I stopped as the tires were shot anyway. I sprung for a new sensor and if it continues, I can program the chip to ignore any knock to a certain MPH and 65mph will get me through the 2-3 shift.
Clint, the soapy water is a good idea but my problem occurs in the upper RPM and boost range although I suppose a minor leak could manifest itself. What I have found in the past is that if I have a minor leak at a hose connection, that puppy comes flying off at 20# boost.
Clint I had the same thought a while ago, but it really won't work very well. icon_sad.gif It would be difficult to find and engine that at any point in its rotation has one valve in each cylinder closed. If any 1 cylinder has both valves open you are going to have a tough time holding pressure. Maybe if you had enough airflow you could do it... But I'm guessing that amount is going to be pretty high.
Funny story, my brother wanted to quiet down his 3" for a trip. He got a can and drilled a whole bunch of holes in it. He reved it up and the can shot out. Our puppy snagged it and ran like hell. icon_eek.gif So he find a piston out of a rototiller and clamps that in. I told him that the pistons have to be in the engine to make more power, he flipped me the bird icon_biggrin.gificon_biggrin.gif
Given the way the knock sensor (piezo-electric transducer) works, it would be my guess that the normal failure mode is not one that indicates excessive detonation. In other words, to output the voltage signal, the piezo-electric crystal has to be deformed / distorted. This happens when shock waves from the detonation vibrate the block. The piezo-electric crystal isn't going to just sit there and create voltage spikes on its own. Given that the same sensor has been used for years on GM engines, I would bet it is pretty reliable. Probably the most common "failure" mode of this sensor is mis-diagnosis!
One further note to BLKMKG, is that yes this same sensor is used in many aftermarket systems (another testimony to its reliability), but the filtering / analyzing of the data it outputs is VASTLY different among OEMs, model year, and aftermarket.
later, Steve
Yes, the filtering etc. is different - an din this case that may very well be wahts' wrong. Heck, ignition energy could be leaking into the sensor lead and causing false readings. It could also be some sort of weird valvetrain bit - who knows? I'll be real interested to see where this winds up and how it gets fixed...
P.S. Scottie, I've got th epics that I took of your car in Florida out of the camera on disk - you want I should put them up?
[ May 02, 2001: Message edited by: BLKMGK ]
